TJ Fest 2021
Hood Vent
Flivver250
Dubai/Florida
A couple weeks ago my buddy's TJ got a fountain of sand covering his hood whilst we were misbehaving in the desert. Looked pretty funny at the time, but for the next two weeks his AC vents have been sand blasting him. Bad juju. Evidently filled his ducts up with fine grit abrasive. I just installed this on mine and got one for him. Using it as a blocker, not a scooper and certainly not as a decoration (but it does not look bad). Live and learn. I suppose I should post a picture of my Jeep with vent scoop installed. My sled is a real camera slut and does enjoy modeling for the group. Shamelessly embarrassing actually.
liquidfluidity
IA....
Are your grill inserts all aluminum or just the center sections? I have been thinking about getting some with a different center but most that I have seen are plastic or partially plastic.
Reactions: Flivver250
dbbd1
go away...
Oregon
I had this one on my other TJ (that one had a CAI through the cowl). It has a lower profile.
Flivver250
Flivver250
Dubai/Florida
They are stick on plastic inserts. No effort.
Flivver250
Flivver250
Dubai/Florida
My hood louvers are aluminum. I did cut out holes with a hole saw for that. As it is extremely hot here, I did this to let heat out after it stops. It does help considerably.
Flivver250
Flivver250
Dubai/Florida
Sure it does, until you get into more difficult conditions where that extra for-looks restriction you added becomes the reason why it can't.
In that event, I grab them with my kung fu grip and pull them off like the decals they are. 2 minute face lift. Thus far, every component of my cooling system is fresh (except the block) and keeping the temperature under extreme conditions exactly where it should be.
Reactions: Tj Starting
Flivver250
Flivver250
Dubai/Florida
Temperature gauge isn't lying. My engine stay right at the temperature dictated by the thermostat. If the engine temperature actually rises I'll certainly try pulling them, but pulling them will not drop the temperature below what it currently runs at so no issue. I watch my gauges and the gauges work correctly so no worries.
astjp2
TJ Expert
Utah and Alaska
Pull them before you have a problem, you are overworking the cooling system which is hard on everything under the hood. Do what you want but we have the experience to help you and wish you the best. Tim
Flivver250
Flivver250
Dubai/Florida
Can you educate me on which what part of the cooling system is working harder? I'm game.
Flivver250
Flivver250
Dubai/Florida
Hotter than the temperature of the engine which is at the same level as everyone else here with a functioning cooling system? Mine runs 200 to 210. Fresh belt, thermostat water pump, radiator, fan clutch, idler, tensioner and coolant, and hoses + clamps.
