It is indeed the angles. The 8.8 looks like to me like it's a "low" pinion axle where as the Dana 44 has its pinion centered relative to the axle tubes. Also it's offset more to the side which probably doesn't help. Secondary is the fact the axle tubes are super thick and it's hard to have enough room to route my slightly larger than stock exhaust over it and the ground clearance at the center of the diff is less. But yes, as Irun said, my DS angle is extreme to the point of binding at droop, plus the double carden joint gets very hot just street driving. I want to lessen the angles by 1) Dana 44 with a higher pinion 2) SS SYE and 3) 1.5" MML over the 1" I currently have.
The ECG489 didn't offer the Eaton locker unfortunately.
