What prevents you from other more serious mods (outboarded shocks/custom arms/geometry correction) I mentioned? Budget or you don't see the need for these with 32s or a bit of both? Just curious.
A big build around 32s would have about a 2" spring and a small body lift for the raised skids. At 2", the control arm geometry isn't screwed up enough to matter much during a climb steep where these things can be a problem.
Regarding the outboard, the benefits would be real. Just be aware that the shock travel closely matches the shock travel. Meaning it may not be feasible to get 11-12" of useful travel the way we can with a good 4" spring. The value comes from the ability to run a nicer tunable shock, splitting the travel evenly, the wider stance of the shocks and the increased opening under the axle from moving the lower mounts behind the control arms. Similar improvements and limitations apply to the front as well.
