it's a slippery slope.
Right!? If it just had___, that's all it needs. I'd be set. But to do that, it needs ___ to do it right. And if I'm in there already, I might as well add ___ while I'm at it. Easy to get stuck in a do loop. Next thing you know, it's definitely not stock.it's a slippery slope.
At a certain point your will add enough weight to sag your stock springs. At which point you will need heavier duty springs than stock, I'd guess you'd only be able to find that along with additional height above stock.
No reason you couldn't upgrade axles, lockers, u joints, etc on a stock height rig.
Right now, it's gears for me. I've been resisting that investment for a couple of years now. 'Cause I know that'll be Crossing the Rubicon. Gears will lead to bigger tires, that leads to a body lift, that leads to a tummy tuck, that leads to...That's pretty much where I'm at right now. There are a lot of things I'd like to do and a lot more things that I would need if I did them.
There are still things I can accomplish as is to make improvements though. Mostly being in the armor dept. but that again brings me to the tummy tuck that leads down that ugly path again. Another small thing I'd like to do is steering gear box skid, but my oddball bumper makes that tricky too. It's a lot like Jenga.
If you ever get a chance to take a ride in someone's rig going through any of the JV trails, take it. You will never utter the above statement again.My original point was the lower to the ground you are, the more vulnerable your oil pan and other undercarriage items are to crunching rocks.
When LCIR was open, we wheeled down there numerous times. You could navigate most of it on a stock height rig. One gent in particular brought out his 98 white Sahara. He was stock suspension with Bulletproof bumpers, monster swing out tire carrier, 10 lb Co2 tank on the rear bumper, winch, tons of recovery gear, hi lift, and he drug over everything. He needed a 2" lift to get back to stock clearances.When is the TJ no longer stock? Is it after the ride height is restored from the added weight of the skids?
You are starting to show a propensity for hanging your hat on dumb shit.Ive been to jv. I've seen the trails, ran what i dared in jeep and jumped on bike for most of the exploring.
I stick to my point.. which is an obvious one.
Rocks are always an issue, especially when going up dry waterfalls and canyons, but when your rocking 31's, every trail with a rock garden, rogue boulder, stump, or deep ditch can be a greater issue.. versus rolling on 40's, which makes some rocks/ditches/boulders a non issue.
Therefore stock vehicles/non built/low to ground, should consider skidplates and underarmor as an early mod.
. . . There's a local Jeep club around here that doesn't really do anything but drive around on flat forest service roads. Many of them don't want to "abuse" their Jeeps. . . .
There are two Cal4Wheel 4WD clubs in my town and one Facebook jeep group. I am a member of both clubs (Black Sheep and the Rat Pack) and participate in runs with NorCal Jeeps from time to time. Each group likes to do different things with varying degrees of difficulty from overlanding to obstacles requiring purpose-built rock buggies. Vive la difference. There is something interesting for me to do offroad almost every weekend, midweek too if I seek out some of the other retired old farts.
Sequioa and Kings Canyon are in Central California, not NorCal.
Its a common mistake. Hell, half the people who say they live in NorCal aren't far enough north to legitimately claim that.
As far as the real NorCal is concerned I know of many dispersed primitive spots and a "secret" lake or two. But if I told you where they are Hillary would have to suicide you.
Yup.
When I was in the modification zone (primarily the spring of 2017) it reminded me of my younger days when I first bought my house. It seemed like every single thing I did resulted in the necessity to do another & it went on for years. Get furniture for the kid, now you have to paint his room, oops now the trim doesn’t match the hallway so that needed to be re-done & before you know it the painting job spreads through the house like a wildfire. Re-do the family room, just some new dry wall & tile flooring right? Hahaha, gotta re-wire everything/add new outlets & fixtures & while you’re at it build a bar that wasn’t there before & about 100 other things… what, now the kitchen looks like shit???? It did end though, I think the last upgrade I did to my house was 10+ years ago & the thought of cracking back into a new one makes the hair on my neck stand up. I’m even at the point where if something breaks I may or may not fix it, becomes a do I really need/want it anymore, I think I’d rather move into a shipping container than embark on another home improvement.
The TJ has been a mini version of that, in 2017 I probably sunk 10k in it building/outfitting it to withstand the type of off-roading I knew I’d be doing. 2018 saw a fraction of that, mostly it was replacing old worn/broken stuff that was still original equipment like shot control arms & a mangled tie rod…, I’d guess maybe a grand or two, that includes new tires. 2019? Exactly one thing, I finally rid the TJ of the one thing I didn’t like about it by tossing a new front bumper on & even with all the bullshit that came with it I’m under $500. Point being I’m on a distinct downward spiral with modifications & I’m pretty much at the point I’m at with my house, zero desire to take on a new project. The TJ is more than capable of doing everything I want to do with it and some; it’s a great feeling when I’m off road and I know I can do whatever I want, really does make each outing pretty exciting. I’m sure there will be odds & ends going forward but maybe not even that; it’ll also be maintained of course but none of us can every get away from that.
Yeah, skidplates are usually one of the first things we recommend here for wheeling. There was a stock TJ that came out Sunday with us, and a few spots he had a very difficult time getting through because of deep ruts with good sized rocks in the middle. Being a tight woods trail, there were no go-arounds.Rocks are always an issue, especially when going up dry waterfalls and canyons, but when your rocking 31's, every trail with a rock garden, rogue boulder, stump, or deep ditch can be a greater issue.. versus rolling on 40's, which makes some rocks/ditches/boulders a non issue.
Fuck off. I respond because others may need to know what is important based on what works and why that sometimes matters. Your insistence in this matter particularly after "peeking" around out there is full on fucking stupid. If I was in need of attention, I'd god damn sure know to use you're instead of your. If you're gonna try and slam someone, at least get that fucking part correct.Then quit responding. Or is your self esteem on the low end and your in need of attention?
