Is Smittybilt really that low quality?
I have the corner gaurds and rear fenders and the coating has held up well... I have some other brand front fenders and its flaking and rusting
Reactions: MikeE024
I would like to get the fenders sand blasted so I could paint them instead, or I just buy some GR aluminum fenders and paint those
My Smittybilt bumpers, swing-out spare tire carrier and flat fenders are 12 years old and flawless. No complaints — durable and heavy-duty.
I live in South Florida — every couple of months + -, I routinely hit the surfaces and crevasses with WD-40 Specialist Corrosion Inhibitor, long-lasting anti-rust spray. (in the tropics, the flat fender seams will eventually show tiny rust beginnings in spots — as long as you’re vigilant, no issues; in the Northeast and elsewhere, same-o, same-o)
Reactions: TheBoogieman
The couple of items I have had that were smittybilt have done ok in the rust belt of New England. BUT haven't had any smitty armor, just a winch plate and couple of antenna bases.
I have had a couple of issues with other brands over the years. Power coat cracks and then salty slurry seeps in and rusts. Every spring I have to look over the jeep and any cracks in powder coating gets wired down and spray painted.
I second someone's comment about spraying down the surfaces with fluid film when mounting them and maybe even annually try and spray some between in any gaps.
Reactions: MikeE024
How bad is the rust situation in VA?
Rust isn't really an issue here until you get closer to D.C./Northern Va. It's more the owners fault IMO. I treated mine with Eastwood products/ drilled frame drain holes soon after buying it. It was originally a Texas Jeep that spent two years in D.C. before I got it nearly 8 years ago.
