I am considering doing this:
NSG370 to ax15 Terminator transmission conversion:
1. Bell housing from advance adapters Part #712590 = 425.00, needed because it puts flywheel position sensor in correct location.
2. Brand new ax15 1795.00 plus 100.00 shipping from Rockland Standard Gear they have them in stock. New version has updated synchronizers.
3. Upper handle of Shifter needed = handle is 177.36 from Rockland Standard Gear. Has to be heated and bent.
4. Clutch disc has to be ax15 style and pressure plate has to be nsg370 style
5.need ax15 slave cylinder kit part # 716340 167.64 from advanced adapters
6. Total cost of conversion = 2500.00 (if a new tranny is used)
But am not sure if this applies to a Rubicon?? Its $2500 to rebuild mine. One guy said you are nuts to do that if you could do the conversion for the same price. Dang...I really wanted an automatic.... Thanks RR
