Cycle your ignition switch On-Off-On (not to Start) a dozen times, pausing each time it's in the On position for 2 seconds before turning it to off before cycling it again. Then try starting it and see what happens. Make sure you pause long enough in the On position each time so the fuel pump can run its full 1.8 seconds before the PCM shuts it off.
