2.5 inch lift, 3/4 inch puck to correct the Jeep’s front end slant, 1.25 inch body lift to allow for a much much needed tummy tuck and 33’s would be a really nice setup.
It would keep the Jeep low on 33 inch tires.
33’s done right will need a re-gear. Dont cheap out now.
if you are running 33’s and doing the whole overland type build, you are going to be adding some serious weight to the Jeep. A 17 inch wheel is perfect for a big brake kit.
The brakes on your Jeep are setup to stop a 29-30 inch tire. You are adding a much heavier wheel and a much heavier tire, not to mention all the gear for over-landing. Add the brakes for safety and peace of mind. You cannot go wrong with the BlackMagic kit.
If you want a really nice setup, add the hydroboost.
