I’ve had both. The Antirock is better hands down, not even a question about it.
It really depends on your needs. Aftermarket sway bars, weather single or double will out perform discos. I haven’t ran an anti rock but wheel with a tj equipped one frequently. It’s scary how much traction & stability is gained by an aftermarket bar! I’m running discos myself but will upgrade to AR in the futureView attachment 37510 Currently running jks quick discos. I’m tossing back and forth the idea of buying the anti rock. But I’m not 100% sold yet. Is there anyone that’s had both that could help steer me in the right direction?
First of all, thanks for your service. If you’ve had “that moment” before you’ll likely have the need for it!I’m pouring more money in to the tj to build after I return from my deployment. I’ve had one stability butt pucker moment I’d like to not have that happen again. Maybe I will get it
Sway bars front and rear will provide stability and predictability by keeping the body centered between the articulating axles rather than flopping from side to side as happens when disconnected. A softer than stock front sway bar will provide both stability and all the articulation you need.
The Antirock is still one of the single best things I put on the Jeep.
2003 Rubicon
I was curious too so I found this. Read it all of the way though and watch the video, I think it will answer most of your questions.What makes it better? Constantly applying pressure? Stability?
After watching the video and reading the comments. I think the front is overkill for me. I have a 2 inch lift with 31's and I pretty much go off-road to haul my quad or go fishing, So it is all unnecessary for me, but for you I guess it would depend on what your plans for off-roading are. One thing about it is if you are set on getting the front you don't have to get the rear, so you can always decide later if you want/need it in my opinion.Now what about the rear anti rock. Over kill?
Oh yeah I’m fairly certain I don’t need the rear at all I still have the factory sway bar connected. I’m just curious what others say is all. As far as off-roading plans I’d like to head out to Moab and Colorado one of these days. Also not have to worry about breaking things on iowa trails so far so goo though but it’s only been out just a hand full of times.
Peanut Butter Jelly Time! Congrats!I just pulled the 381 dollar trigger on it :banana:
