Re-reading your original post, looks like these are Savvy arms from 2 years ago. I ordered my Savvy kit in Aug 2020 and it came with the hardware they could get at the time (COVID) - but wasn't right for thread engagement, and my original hardware look like yours.
Here is the original nuts engaging the original bolts:
You'll note your kit, like these pics, show a nylocs and extra-thick washers. You want at least 2 full threads to consider a bolt/nut fully engaged.
I emailed Gerald and he shipped out new nuts & washers (at no cost) that they include these days (and apparently before the COVID inventory-restricting days). I let him know I did not feel safe with my family in this Jeep without proper thread engagement. Despite other Savvy issues on availability (these days) and no stickers (contact Jerry), Gerald was very responsive on my concerns!
Much thinner (more typical) washers & non-nylon lock nuts resulted in much better thread engagement!
Recommend you reach out to Gerald (gman savvyoffroad.com) for a new set of washers & nuts.
If you didn't put in BMB alignment slot fillers - recommend those too. (I had a HP Dana 30 & them put in new lowers - so didn't have an alignment slot to concern myself with).
Can't say it's your issue but it is a potential future problem.![]()
So mine did come with the super thick washers and nylocs nuts and ever since I installed them I’ve always been pretty skeptical of the setup. The bolts to me all seemed like they should have been 1/4” longer.
The front lowers already have the BMB washers as well. These are even thicker than the supplied washers, so they have less engagement than the rest. I’ll have to shoot Gerald an email and see what he says.
I can't keep threads straight... lol. I'm still concerned on using those thick washers and nylocs - not enough thread engagement. May not be this new clunk but I don't want a future failed of a nut twisting off for anyone... That's what cause me to reach out to Gerald and the new setup has much better thread engagement.
Definitely the same clunk as before. As the week in the Mts went on, the clunk came back occasionally and by the end of the week was back how it was. I retorqued to 150 yesterday but haven’t driven since to verify it’s gone again.
My bolts all have at least a few threads past the nut and I use Stover type (all metal with deformed thread) locknuts.
You're sure the bolt is class 10.9? And make sure you're using the correct torque specs. In addition to size and strength class, they vary based on thread pitch and whether the threads are lubricated. If it's been over-torqued, it's cooked and needs to be replaced.
They are whatever bolts savvy supplied at the time. Could 150 be too much for it? That’s the highest my to wrench goes, so that’s what I did yesterday on it.
