Great, it's geared properly. The main potential issue I'd be alert for happening is the TCM (transmission control module) was integrated into the PCM for the 2005-6 model years. Heat build-up inside there can cause it to (literally) blow which is fatal for the PCM/TCM. The bad news is another factory PCM won't fix that problem, it'll happen again. The good news is
www.wranglerfix.com has a replacement PCM that permanently fixes the issue.
One more possible issue for 2005-6 models is the oil pump drive assembly aka OPDA can go bad and cause accelerated wear on the OPDA gear and/or camshaft gear. If you start hearing some chirping/screeching noises it's time to install one of the aftermarket OPDA fix kits. I believe the Crown brand to be the favorite for that fix.
