Which worked surprisingly well. I obviously still had to use a press afterwards to straighten it more, but overall we did a very good job for a trail fixThis was the fix.
That repair was so epic. But UT worked.
2023 because of Mike!Well when we are all ready...
I don't know specifically idk whats not snowed in. Off pavement is that specific enoughWhere do you want to go?
Sounds funSpring creek is open to the rock garden last I checked. I need to find a close trail to Denver in mid/late June to take my niece on
The joys of home ownership!The house we moved into was built in 85. It has what I assume is the original sprinkler control box. There is a valve box in the backyard so I replaced the vacuum breaker and fired the system up. 3 zones, and I could only find three heads that were broken or just trickled. I could never find another box for the front yard. Fast forward to a couple weeks ago and i replaced two freezeless outdoor wall faucets which required me to go in the crawlspace to turn the water off. I noticed thin wires leading to the north side of the house. Went outside and found the wire was cut at the wall. So there is a front system! Today mowing the lawn I found the other end of the cut wires barely poking out of a walkway.
I suspect the system froze in the past and the previous owners just left it. The backyard should be fairly easy to repair, I'll just cut the line at the valves and trench in new ones since the yard isn't so great anyway and clearly it's been landscaped over the old heads. The front might be a little harder, but looks like I have a project this summer
Tell me about it. Day 1 of new paint, new HVAC next weekThe joys of home ownership!
I hardly recognize it.
Which sprayer are you using again? I'll need to touch up just a couple small areas in the next year or two
I did the Magnum X5, couldn't imagine painting a house without something like it.Which sprayer are you using again? I'll need to touch up just a couple small areas in the next year or two
You painted your own house?I did the Magnum X5, couldn't imagine painting a house without something like it.
Yeah, I stopped playing people for jobs I can do after getting less than desired quality too many times.You painted your own house?
