Gulches is fun but small. It’s around $50 I believe on the weekend and to camp. I stayed on the easier trails due to my 4hour commute and wanting to drive back home.
Is this what you're talking about in SC? http://www.sandblastrally.com/ (looks cool, but the only thing my Jeep is racing is the gas pump)
Or are you talking about something in NC sand hills?
I'm hoping to go down there sometime this month, once I know what weekend I'll let yall know
I posted this somewhere on here.. But here it is again.
Depending on when or if you all go, I’d make another trip.
If it makes you feel better I just got mine running last night. Now I have DW and I think it's the track bar joint at the axle. I also got some used double adjustable upper control arms to put on.Hopefully I can finish my Jeep by then. Just now finished my rear track bar..took me a whole f’in week! Need to cycle the suspension and bump stop the axles to install shocks, also need to instal the JB sssye and order my DS. So much to do
well dang, you got your work cut out for you!Hopefully I can finish my Jeep by then. Just now finished my rear track bar..took me a whole f’in week! Need to cycle the suspension and bump stop the axles to install shocks, also need to instal the JB sssye and order my DS. So much to do
What's the plan to fix the TB joint?If it makes you feel better I just got mine running last night. Now I have DW and I think it's the track bar joint at the axle. I also got some used double adjustable upper control arms to put on.
It's an unknown brand track bar but it looks like Rubicon express or RC. If it is RE then they make a rebuild kit for the joint. If it's RC then I'm buying another track bar!What's the plan to fix the TB joint?
I have a fairly new stock front track bar you can have to fill in till you get a new one.It's an unknown brand track bar but it looks like Rubicon express or RC. If it is RE then they make a rebuild kit for the joint. If it's RC then I'm buying another track bar!
I appreciate the offer but the original frame mount is gone and has been replaced with a johnny joint or heim type joint on the frame.I have a fairly new stock front track bar you can have to fill in till you get a new one.
your axle might be a bit off center, but its better than DW!
But the joint is on the track bar, not the frame...I appreciate the offer but the original frame mount is gone and has been replaced with a johnny joint or heim type joint on the frame.
Yes, the joint inside the track bar that connects to the axle is the one that is bad. The frame side is no longer the original mount, it has been replaced by a heim style stud.But the joint is on the track bar, not the frame...
oh, could you post a pic when you get a chance?Yes, the joint inside the track bar that connects to the axle is the one that is bad. The frame side is no longer the original mount, it has been replaced by a heim style stud.
Hmm, I still don't get it...Here is a link to it that shows good pictures of the frame joint. I'm out of town so I can't take a photo.
https://www.4wheelparts.com/p/2006-...RBd9ClNAp4q9lCiWCkCdm4HpeFmqMCUQaAvxaEALw_wcB
When I pull it off, I will take a picture. I believe that it is the same stud but different bushings to accommodate the heim.Hmm, I still don't get it...
Was the mount I circled in the picture below modified at all on your Jeep, Drilled/Cut etc?
I'm not talking about the TB here, just the mount.
ah, that makes sense, if you're able to take the bushings out my offer still stands...When I pull it off, I will take a picture. I believe that it is the same stud but different bushings to accommodate the heim.
