North Carolina List of Carolinian off-roaders
I'm hoping to go down there sometime this month, once I know what weekend I'll let yall know
Hopefully I can finish my Jeep by then. Just now finished my rear track bar..took me a whole f’in week! Need to cycle the suspension and bump stop the axles to install shocks, also need to instal the JB sssye and order my DS. So much to do
If it makes you feel better I just got mine running last night. Now I have DW and I think it's the track bar joint at the axle. I also got some used double adjustable upper control arms to put on.
well dang, you got your work cut out for you!
It's an unknown brand track bar but it looks like Rubicon express or RC. If it is RE then they make a rebuild kit for the joint. If it's RC then I'm buying another track bar!
I have a fairly new stock front track bar you can have to fill in till you get a new one.
your axle might be a bit off center, but its better than DW!
I appreciate the offer but the original frame mount is gone and has been replaced with a johnny joint or heim type joint on the frame.
the joint bolts to the frame, has yours been modified somehow?
Hmm, I still don't get it...
Was the mount I circled in the picture below modified at all on your Jeep, Drilled/Cut etc?
I'm not talking about the TB here, just the mount.
When I pull it off, I will take a picture. I believe that it is the same stud but different bushings to accommodate the heim.
Reactions: thekidwithquestions
