Lockers don't engage
TurboTJ
Walnut Creek, CA
I have a 2006 TJ Rubicon with the original lockers. Yesterday I tried to engage them and neither would. The dash indicators flashed continuously but neither engaged even after jockeying back and forth somewhat. I have done zero troubleshooting so far. I just wondered if there is a common point of failure that would affect both lockers. I have not used the lockers for quite awhile but they did work when last used.
No S-turns and no troubleshooting so far, not even listening for the pumps. I am flat-towing the Jeep home now and will start checking things when i get there.
Most likely no air is making it to the lockers-
If the pumps run, check the lines-
If the pumps dont run, swap a relay in and see what happens.
