jk44s are out and currie hp60s are in.
Got a really old front axle off marketplace. 68” wide, Detroit locker with 5.38s. I’ll be going with 8 lug unit bearings to match the rear. Some ass hole reamed the knuckle’s out but hopefully can save them.
Had a rear housing on hand, with some unknown Dana 60 spindle. Really struggled to find hubs that work on it. It has a 2-7/8” seal surface, 2.250” inner bearing race, 2” outer bearing race, and 2” threads. So some flavor of Dana 60 or 14b. The problem is the bearing separation, these spindles are quite long, I got a set of 01 ram hubs from a friend and with .200” shim under the outer race, they will work. With these hubs, we’re sitting right at 67” wide without rotors.
If anyone has any idea what these spindles are based off these measurement’s I would love to know for curiosity sake.
View attachment 699015View attachment 699016
Got the JT front brake kit from currie, it uses dual 51mm piston calipers and a 14.25” rotor. I was suprised to find out how affordable this kit was from them. I had tried Blaine for brakes but was told to fuck off just because of who I’m friends with. Talk about drama…
On the rear I am just going to use a wilwood dynalite on some flavor of 8 lug truck rotors.. also going to give the wilwood electric parking brake a shot if we can fit it.
Otherwise I’ll be sticking a 35 spline arb, super 60 5.38s, and some Dutchman flanged shafts in this housing.
Very cool.
Mind sharing what you paid for that axle? I have a back burner project to replace my pro rock with something wider. 68" would match my 14 bolt.
