Buckle up this is going to be a long story.... Hopefully someone has some knowledge on this, thanks in advance for any information.
I bought a 2004 TJ 4.0 5 speed a few months ago, 174k documented miles (odometer didn't work when I got it, not sure how long it didn't work but it is fixed now)
Since I bought it I had to put new cats on it (front one was broken up and plugged like has happened to others) I pulled the oil pan off to just inspect everything and replaced the bearings anyway when I was in there. (SIDE NTOE the oem rod bearings had the oil hole, the replacements did not) It then eventually it developed a knocking type sound loud when cold then quieter, when warm- I thought it was a lifter, bearings looked ok. So i decided to tear it down for an in-frame rebuild. Everything was removed except cam/timing chain, and crank.
Results of disassembly inspection were 4/6 pistons had cracked skirts, though none were broken off, and one of the lifters on #5 cylinder was difficult to get out and had some fine particles that stuck to the magnet when I removed the lifter. I cleaned all that out with the magnet. Also, on the head, the intake valve on #6 cylinder was corroded and not seating. Was going to lap the valves but I couldn't get a clean seat, so I ended up taking the head with a new set of valves to a machine shop.
For the rebuild -
I honed/deglazed the cylinders and got new pistons and rings and put them in.
Rolled in new main bearings and installed new rod bearings (these had the oiling hole in them same as OEM).
New set of lifters/rockers/pushrods
Head job, pressure checked for crack, cut new valve seats, new valves and guides, decked surface. - basically a new head
Reassembled everything and it fired right up - held 2k rpm for 20 minutes for break-in since I had new lifters. I used lucas TB zinc-plus break-in additive.
I went for a test drive and when I got to a stop sign, clutch in and engine came to idle, oil pressure went to zero and check gauges light came on, (I know its a dummy light for basically you have pressure or you don't, I believe i have read the cutoff is 6 psi?)
Got back home and went to pull the oil cap off the vale cover to make sure I could see the oil getting up to the rockers and when I went to remove the cap I could barely get it off there was so much vacuum. Once I got the cap off though, and the vacuum was equalized the pressure gauge showed ok oil pressure again and the warning went away. It turns out some time before I got it, that the front pcv fitting in the valve cover that is supposed to be open was replaced with a rear one that has the restriction orifice in it. I think this was never a problem before because the engine had enough blow-by that it got enough air to equalize, but with the new rings and good seal it was pulling a vacuum. I replaced with the correct fitting and thought it was fixed.
The next day I started it up and oil pressure read zero, again oil was getting to the rockers, so figured its the sending unit, (it had also showed zero one day when leaving work but shut it down and restarted it and it was good again, didn't think anything of it until now) replaced the sending unit and sure enough showed oil pressure again (cold), so I went for a drive again. Once it got to operating temp it again showed low pressure.
Neither the oil or coolant look milky indicating a leak on either side.
So now my next step is going to be to hook up a mechanical gauge to see what my true oil pressure is and go from there. Probably will pull the pan again to check bearings too. In the mean time I am all ears on what anyone thinks could be the problem? Could the excessive vacuum have pulled oil out of the journals during break-in and worn the bearings and now I have excessive clearance contributing to the low pressure? The original rod bearings that I took out when I replaced them had the holes in the end that allow the oil to pass through the connecting rod to oil the cam I think, the first time I replaced the bearings they didn't have these holes, read alot on that and concluded that bearing manufacturers decided they didn't need them... anyway the replacement connecting rod bearings that I put back in with this rebuild have the hole again, could that be just enough to make my oil pressure too low when warmed up?
Again sorry for such a long post and I know there are thousands of low oil pressure posts and hate to add another one but I have a sort of unique situation with the vacuum and not sure if that could be contributing to any of my problems. Thanks everyone.
For the rebuild -
