From Sanderson:
No Gaskets??? That is correct. Please, do not use a gasket at header flange. A collector gasket, yes.
If you use a gasket or too much silicone at the cylinder head flange, you will likely experience sealing problems.
- Apply just a thin smear of high temperature silicone on the entire raised surface of the header flange.
- Let the silicone fully dry (overnight is preferred).
- Bolt the header to the engine.
Even a clean installation such as the one shown below (with a gasket installed) can have sealing issues if the instructions are not followed. This header flange started leaking a few weeks after this picture was taken.
Let it cure without the header bolted on? That's weird as hell
