Before the DW issues I had it lower, but when I put my DS back in I had vibes. It was 1deg lower than the DS. So yesterday I spent dialing out vibes. I adjusted in .5deg increments up to pinion 1deg higher than DS. Sweet spot was right around equal, which is where it's at now. With that said, the vibes were minimal at 1deg lower amd only really present above 70.the pinion looks high. if so, fix that which should address the interference.
