How'd the Baja bosses do compared to the MTRs?Ol Sunny Side Up is back in action! After getting the alignment dialed in, I planned a quick trip to 5 mile pass in Utah. A close to home wheeling spot that offer some challenging trails/lines. A few friends joined. We had 3 LJ’s and @TJustin TJ with us. Great group!! I’m pumped with the new steering and track bar set up. I was able to climb up the obstacle that had bent my previous steering on a past trip. I’ll call it a win. I still need to tie up some loose ends, but I’m getting close to having it 100% back together. View attachment 268608View attachment 268609View attachment 268612View attachment 268613View attachment 268614
Much better! Not a fair comparison tho. The last time I ran this trail it was very muddy. These rocks are granite and slick enough dry. Adding water and mud makes some obstacles near impossible. But nonetheless I am impressed and happy with the tires!How'd the Baja bosses do compared to the MTRs?
Good eye...Yes it is disconnected. The new steering will not work with the factory mounts I had to cut them off. Plan A didn't work. Plan B is Clayton offroad high steer sway bar mount, But of course they are about a month out. So I just tied it up under the fender. If the Clayton mounts don't work, I'll move onto making some custom ones.Great seeing the yellow beast in action. Is your antirock disconnected?
That’s good to hear! I was worried about long term wear. They seem like quality partsI had this exact same hub/QD setup in my old first gen Miata for years and loved it. NRG makes some of the best quality hubs I’ve used. Looks great and unlike the cheap eBay ones, the ball bearings wont get loose and develop play in the wheel over time.
Right? I was excited to pick them up. I’ve been close to buying some that were much higher in price.That's cheap for a set of doors!
How exactly is that done? I want to accomplish the same thing…For the airbag light, I wired in a resistor so there is no warning light on the dash.
When you pull the airbag and unplug it, there is a 2 wire connector. The hub comes with the resistor, you simply plug the resistor into the connector.How exactly is that done? I want to accomplish the same thing…
Figured it was time to get the antirock hooked back up. With the WJ knuckle swap, my factory sway bar mounts were not going to work. They got chopped off. I needed some that were much higher. I decided to give the Clayton high steer sway bar mounts a try. Unfortunately they weren’t quite high enough! So a little bit of cutting, welding and grinding, I got them where they needed to be. Everything now clears at full stuff and full lock both ways. I’m happy to have the antirock back connected! View attachment 269471View attachment 269475View attachment 269472View attachment 269473View attachment 269476
