I know this isn't exactly a straight-forward answer, there's a lot that goes into it. So, I'll start with the basics and you guys can give me feedback and I can fill in the gaps on anything I didn't specify initially.
My Magnum V8 swap is nearing an end. The past 2 days have been spent positioning the engine in the frame so I can get the engine mounts welded in place. With all of that I have gone from an AX-5 transmission to the NV3550 out of a Rubicon so it has the 241R transfer case behind it. I'm putting a Ford 8.8 in the rear and hopefully within the next week (or so) having the Barnes axle truss welded in. As for right now I have about 3-4" of extra room on the backside of the heads before they're against the firewall. Now I know it's fairly common for people that are doing the Magnum swap to beat in the firewall in certain spots to get everything to fit. That's not my issue (currently). (This is where a lot of non-techincal terms are going to be used due to my lack of knowledge of the actual names) The hole where my shift lever goes in the top of the transmission is about 5-6" in front of the hole in the floorboard that the shifter is suppose to pass through. I don't really mind having to cut or fabricate an alternate hole in the floorboard to compensate for the difference and I'm leaning towards that option right now because I'm more worried about if I push the engine back as far as I can (plus extra room after altering the firewall) how short will my driveshaft be? I can't pull a true measurement right now of the distance from the back of the TC to the yoke of the axle because I don't have the previous axle in currently and even so, that wouldn't be the exact same measurement as I'll have in the end.
So back to the original question, how short can my rear DS be? Would you push the engine back as far as possible and attempt to make the hole in the tub and the trans match up? Or should I leave everything slightly forward (we'll say 2-4") and have a little longer DS? I know the second option requires cutting the opening in the tub and possibly bending the shift lever a little too so I'm not punching the dash every time I go into 1st, 3rd, and 5th gears. Oh ya, I have a 4" suspension lift, getting custom driveshafts made, adding a 1" body lift (probably) to help tuck the trans up a little more, and adjustable upper and lower control arms in the rear. Don't know if any of that changes thoughts or what not. Thanks again for the input.
