That's my biggest concern about the longevity of my TJ...and my 2001 F250... availability of affordable wiring harnesses.
Not that I can't grab one (for now) from a junkyard.
Just concerned...as I am sure you are...about the crispness of old wire.
Well, I had been concerned about that since I saw plenty of damage in that one area, but I'm now pretty well convinced there was an "event" of some sort that cause all that. Why would like 8 wires go bare in the middle of the harness at the exact same spot? Rodents? Possibly, although there was no visible damage to the loom, and there was some evidence of heat damage.
But there are 2 reasons why I'm not super concerned:
1. I re-loomed the run that goes to the taillights. That wire was soft and relatively clean...a few sections looked nearly brand new. I actually re-loomed everything I touched (which I highly recommend, my loom broke if it heard me talking about it from the other room) and found that the wiring was in great shape everywhere else.
2. It honestly was not at all hard to fix my issues. The general reaction here was pretty much "omg that's a flipping disaster, you should sell it for parts" but it took very little effort to clean up & resolve. Granted, I have the right supplies to make these fixes correctly and I enjoy the wiring aspect. If I have another electrical problem, I'm not the least bit concerned about fixing it with parts I have on hand.......
.....except connectors. Sourcing connectors hasn't been hard thus far, but you have to know what you're searching for which can be very hard, and they all seem to be in the $20-$30 range each. You can de-pin them but you can run into instances where you need to replace the individual terminal, so you have to have the correct ones on hand or know how to search for that inventory. Or get good at soldering or something. IDK. Absolute worst case scenario, you could just replace it with an entirely different connector, but even that isn't always directly possible — case in point PCM connections or sensors with an integrated connector (i.e. 4WD indicator or speedometer gear).
