That’s a stupid idea, Ras. Don’t you know that would make it a low pinion??.Just flip it over
GIven your affinity for lots of cutting power do you find that little drill press to be sufficient? My next tool purchase will be a beastly drill press... or ill give up and get a grizzly.Those of you who have followed my build over the years will recall occasionally seeing me pull out my big Laguna Band Saw. Another of my hobbies is wood working (I occasionally build fine furniture - I'm also a hack at that hobby) and for woodworking this band saw is about the best. 18", 4.5 Horse Power Baldor Motor running on 220, and a 155" blade. I've resawed 16" oak on this thing. It weighs over 500 pounds - it's a beast.
But, it's a single speed at 3500 feet per minute, and because of that it cannot be used for ferrous metals like steel (although I have used it to cut aluminum). There have been countless times I've wished I could use it to make a cut in steel.
Over the years I've considered many ways to make it a variable speed saw, including gearing or running a variable frequency drive, but none would have been practical on this saw. So, I decided to sell it and replace it with a vertical band saw which could also cut steel.
It's a pretty expensive and specialized piece of machinery, so I figured it would take a while to find a buyer. It sold in 2 hours on Facebook Marketplace. I bought it new in 2006 - and I sold it for more than I paid for it. I can't believe how fast it sold. I'm also sad to see it go.
Meanwhile, after a bunch of research I've ordered a new Jet VBS-18MWEVS 18" Metal / Woodworking saw which should be very close to the Laguna in wood, and very good with metal. It will run from 100 fps up to 3600 fps. It's also a beast. As with everything else right now, there is a bit of a delay - but it should be here in early January.
Ouch - that cuts deep, Boom...GIven your affinity for lots of cutting power do you find that little drill press to be sufficient? My next tool purchase will be a beastly drill press... or ill give up and get a grizzly.
OH wow, ya that's a pretty powerful drill press. You think that's the min for serving jeep fab needs?Ouch - that cuts deep, Boom...
I think the picture makes it look smaller than it is. It's a 20", 1 3/4 hp with a 3/4" chuck. It stands about 6' tall. It works well for my needs.
You can certainly get away with something smaller, but Trevor's advice is spot on. I'd rather have something a little too big, than a little too small. Before I had this Jet I had a smaller Delta woodworking press - very similar to the Delta in Trev's picture above. It was frustrating once I started getting into bigger bores in metal.OH wow, ya that's a pretty powerful drill press. You think that's the min for serving jeep fab needs?
That thing is sweet, Trev. Is it tough finding bits for it? I've never seen a press without a jacobs chuck. What is that style of "chuck" called?Not trying to start a dick swinging contest or anything, but you can't beat old iron when it comes to certain things. Drill presses are one piece of machinery that benefit from the good old days, but are still simple enough machines that pretty much anyone can rehab one.
I'd keep an eye out for something older, at least 17" or bigger. The Delta 17", Buffalo Forge 18", Walker Turner 20" are all very nice machines, somewhat abundant still, and just a lot heavier built than anything you can buy new for a similar, but more often higher price.
I didn't do a very good job capturing the difference in scale, but this is my 20" Walker Turner next to my old 15" craftsman. Not even a comparison between the two in actual use, and having a smooth running drill press that doesn't slip belts, and doesn't chatter everytime it's used is an absolute pleasure.
Not sure on the total weight, but I could pick up the Craftsman and carry it sideways, even with the motor off on the WT I can barely slide it around, don't think even two big guys could move it around very well
View attachment 289715View attachment 289717
Very nice. I'm also a hack woodworker. Haven't done much since I bought the Jeep though. I picked up the wood working from my dad, who has some really nice tools. He has a single speed jet band saw, 18 inch. Very niceThose of you who have followed my build over the years will recall occasionally seeing me pull out my big Laguna Band Saw. Another of my hobbies is wood working (I occasionally build fine furniture - I'm also a hack at that hobby) and for woodworking this band saw is about the best. 18", 4.5 Horse Power Baldor Motor running on 220, and a 155" blade. I've resawed 16" oak on this thing. It weighs over 500 pounds - it's a beast.
That is one beefy axle. I love the image file name, which is appropriate:Here is the front axle you need.
https://www.wideopendesign.com/dana...rF1GFMOTgl8qg6sxLdpfk0FtpdYI1OEVDdjx_0VQEYgPE
That is actually just the spindle, some of the older ones liked to have the spindle protruding out to ease the process of ejecting the morse taper with a drift. Your drill press uses the same style of spindle, though you have to extend the quill to expose the slot for the drift.That thing is sweet, Trev. Is it tough finding bits for it? I've never seen a press without a jacobs chuck. What is that style of "chuck" called?
What's wrong with pickles!?
That's hilariousIf you have followed me for a while you know that I have a Grandson named Luke (I call him LJ - but no one else does...). I believe reading is very important for a developing mind, so I picked up a book for LJ for Christmas.
It is a heartwarming story about a snow plow and a tow truck who save Christmas.
My wife loves books and has them all over the house. I wonder if she'll say anything when I get one of these as a coffee table book?If you have followed me for a while you know that I have a Grandson named Luke (I call him LJ - but no one else does...). I believe reading is very important for a developing mind, so I picked up a book for LJ for Christmas.
