To allow for cooling, and reduce the weight, next I hogged out a bunch of material with a few hole saws on the press.
And then threw on some paint.
Nice work, you guys are forcing me to upgrade my sound system.And here is the finished product. I'm not going to start the wiring today, because, ya know...snowin'.
View attachment 303008View attachment 303009
1) Correct. Wire straight from amp to sub bypassing stock wiring.I'm doing some prep work getting ready to wire the input and output side of the amplifier into the Jeep. The input side is a piece of cake - four RCA connectors for the main speakers and two for the sub. For the output side, looking at the Jeep's wiring diagrams the front and rear speakers are clear enough with four dedicated connections. But the sub-woofer - not so much.
In the factory wiring for the stereo, there is no specific connection to the sub-woofer. The factory sub-woofer is wired by splicing into the wiring for all four of the main speakers, along with a 12v connection to the radio, and a fused 12v ignition switch connection.
My plan has been to use the stock wiring for the front and rear speakers - it is 18 gauge and in good shape, although 16 gauge would be better for the power from what I know. I am still giving some thought to swapping it out.
Two questions:
1) On the sub-woofer, I think I need to bypass the stock wiring and go straight from the amp to the sub. Does that sound correct?
2) As I recall there are two (+) and two (-) terminals on the sub (I know there is a name for that, but it escapes me at the moment). As there is only one (+) and one (-) coming out of the amplifier, how do I wire it into the sub? In series or in parallel?
I'm hoping some of the audio guru's like @skrelnik, @JMT, and @Jerry Bransford, or anyone else who knows more than me, can give me some advice. Thanks in advance.
If the sub has two sets of terminals, that means it's a dual voice coil. You'll need to look at the speaker doc and the amp doc to find out how to wire it. You want to go with the lowest impedance connection your amp will be stable at. IIRC the Picasso nano will go to 2 ohm.I'm doing some prep work getting ready to wire the input and output side of the amplifier into the Jeep. The input side is a piece of cake - four RCA connectors for the main speakers and two for the sub. For the output side, looking at the Jeep's wiring diagrams the front and rear speakers are clear enough with four dedicated connections. But the sub-woofer - not so much.
Two questions:
Two questions:
The sub is a bazooka 6.5" dual voice, 100 watt at 2 ohms.1) See @JMT above
2) Is the subwoofer rated for 1 or 2 ohm? The Soundstream amplifier is rated at 200 watts at 4 ohms or 350 watts at 2 ohms. Depending on which ohm version of subwoofer you purchased will tell us how to wire. Confirm the subwoofer specs or send the product/model number?
2) I don’t know enough about your system and whether you are wiring for 4-ohm or 2-ohm. Someone like @skrelnik would know more about that than me.
Thanks guys. That's a big help.If the sub has two sets of terminals, that means it's a dual voice coil. You'll need to look at the speaker doc and the amp doc to find out how to wire it. You want to go with the lowest impedance connection your amp will be stable at. IIRC the Picasso nano will go to 2 ohm.
That's exactly it. I pulled up my original sales receipt and it is listed as:I searched for a manual but could not find one. Do you happen to have the manual? If not, you can either test the speaker or just assume, which I do not like to do, that the Bazooka speaker has a pair of 4 ohm voice coils, so if you wire in parallel it would pull 2 ohms and the 100 watts.
I make that assumption based off that manufacturers love to inflate numbers and show their products best performance.
Is this the speaker you have?
https://bazooka.com/products/6-2-ohm-dual-voice-coil-replacement-woofer-for-bta6100
Sooooo, here is my current understanding:
My Bazooka dual voice coil, 2 ohm, 100 watt sub wired in series is 4 ohms. Wired in parallel it is 1 ohm.
Looking at the documentation for the Picasso Nano Amp, the sub channel has no rating at 1 ohm, 350 watts at 2 ohms, and 200 watts at 4 ohms.
Does this mean that I should wire the sub in series for 4 ohms? Or do I have the wrong sub for this setup?
