Over on Basket's build thread the subject of transmission cooling came up, and it triggered a thought.
I run the old PSC dual cooler setup, the left side being for the tranny, and the right side for the steering.
Here it is in its current state:
It's always worked fairly well for me, but the memory Basket's thread triggered was that on two occasions in Moab during long uphill runs in high range, during an 85+ degree day, my tranny temp hit 220+ and touched on 230 for just a minute. It normally runs no higher than 170.
For Basket's rig,
@jjvw recommended the Setrab 53-10748-01 oil cooler for the tranny, which is what JJ runs. Blaine recommends this cooler as well. Compared to mine, it appears to be a much larger capacity cooler with larger fittings (all mine are -6). This is it:
https://www.amazon.com/dp/B07C64FTTK/?tag=wranglerorg-20
So I started thinking....
If I do away with this PSC setup to upgrade the tranny cooler, I also have to come up with another solution for the steering. I run hydro assist steering, and also hydro boost brakes, and with this setup in the past I have run the extruded aluminum style cooler and had bad over heating issues on two occasions - resulting in my steering locking up. As a result, I've not been a fan of that setup, and since I replaced it with the PSC setup above I've had no more problems with the steering.
@Apparition mentioned he is running this steering cooler setup from BMB, and it has worked well. JJ also runs this setup I believe.
https://shop.blackmagicbrakes.com/8...ar-Bracket-Hose-and-Fittings-8-COOLER-KIT.htm
One thing I noticed in the description is that Blaine runs all -8 returns with his setup, and as I mentioned I run all -6.
So, I called
@mrblaine to get some advice. We talked though my rig's situation and he said that his -8 TJ Steering Cooler setup would work just fine, and would likely work better than my current setup even though I'm having no issues. He did think that my running -6 return lines the last time I ran the extruded aluminum cooler could have contributed to my overheating issue. In fact, with my setup he was surprised that I had any steering at all when I was hard on the brakes - but that's not something I've ever experienced.
Blaine also told me the limited capacity of that PSC cooler when used for a tranny was the reason they stopped selling it.
And with that input, I ordered the kit. Blaine also said he would get me the fittings I need to install the Setrab cooler (which I also ordered - thanks JJ) and also a different fitting for the low-pressure connection coming out of the hydro boost. As usual, he was a great help and spent a good deal of time on the phone with me doing so.
So....squirrel. While I have the front end apart fixing the grille I'm going to update my tranny and steering cooling systems.
