I have a 2006 Rubicon with the 4-speed automatic transmission and Dana 44s in the front and rear (I believe it's the 4.10 gearing). I want to lift it 4" and put 33" tires on it (probably 33x10.5—I like the pizza cutter look).
My goal is to have a very capable rig to take on a trip from Florida all the way up the west coast into Canada (stopping everywhere in between). I want to hit a lot of trails on the way and take my time. The Jeep is also my daily driver, so I want a good mixture of comfort and versatility while off-roading. The trip could last anywhere from a month to a few months (my wife and I have a business that we manage remotely, so there's no real time frame).
My current budget is around $4-5k for the lift (the wife has approved, with little to no convincing!). Is that a realistic budget?
So far, I've learned that I have a few options:
• Curry or savvy 4" suspension lift
• OME 2.5" lift + 1.25" body lift (just under 4")
• Custom pick-and-choose lift
It seems that many people recommend the 4" Savvy lift (I think this one?) and the Rancho RS5000x shocks for a top-of-the-line rig. The total is around 3k for parts alone.
My questions are:
1. Is the Savvy lift kit all-inclusive? Or are these other components that I will need to add?
2. I read that I won't need an SYE with the Rubicon transfer case. Are there any parts of the Savvy 4" lift package that I won't need?
3. I have only a small amount of experience working on Jeeps, so I may have a professional install the lift. About what sort of price am I looking at for installation? I live near Daytona Beach, FL if that helps me get a closer idea of pricing.
4. Will the OME + 1.25 BL work/feel just the same? Or am I better off spending the extra money for the 4" suspension lift?
5. Do I need to regear? I will likely spend a lot of time on the interstate, so I don't want to have problems speeding up/merging. If I do need to regear, I may end up going with the OME + BL set up so it works within my budget. But a 2.5" lift would also eliminate the possible need for a regear, wouldn't it?
6. Are there other options that I should consider? Would a pick-and-choose strategy—even though I don't know where to start—help me save money and build a better lift?
7. I have a winch (on the factory bumper) and a couple of smaller things installed (like an air compressor), is there anything I need to consider for the extra weight?
Although I've done a ton of research over the last couple of months, there's just so much to learn. I read through the beginner's guide to lifting your Jeep forum that Chris started, which was very helpful. However, I'm hoping you guys can help give me insight into what the best option is for my rig and budget, and help point out anything that I've missed. Links to products would be helpful too.
Thanks in advance.
My questions are:
Thanks in advance.
