Honest question here - if the Jeep sees a lot of pavement, why not install an LSD instead of a locker?
LSD is fine if you never see dirt or only do fireroads
I found that the LSD was very good in the dirt and loose, sandy areas. As long as both tires are on the ground, it works very well. It’s when you get one tire off the ground that it doesn't work well, which doesn’t happen in the dirt or sand.
Appreciate OkieJoe bringing this up.
Had a great ride yesterday and needed 4 low (2001 Sahara 3.73 and 33s- factory Dana 44 ‘anti spin’ ) to get through some deep muddy ruts and guy in front with a JK and a rear locker stayed in 2 wheel drive… he said get a rear locker, he can go places in 2w with locker that 4 wheel without can’t go. Weasillee says if only going with one locker get the front.
I need to learn more about this, I’ll search more threads.
FYI- I am completely happy with 3.73 with 33s and a manual transmission. Most people I know regeared but all with an automatic.
But
Front or rear locker debate will likely never go away. Get one and you’ll see why you want two. Front great. Rear great. Front and rear greater.
Based on the OP's description of a "fair amount of pavement", not one person asked how much "off-roading" he/she will do and if so, to what extreme? If it were my Jeep and saw 75% road, 25% light wheeling, an Eaton TrueTrac would be my choice.
Our Jeep is used as a daily driver and occasional trails . I have been happy with the Trutracs . I can't tell any difference on the road from when it was stock , but off-road traction seems to have greatly improved.
