I am getting started building a custom long arm suspension for my 98 wrangler. I am building axle trusses for my dana 30 and 44 and want to extend the frame side mounts as close to the transmission crossmember as i can for better angles since I have a 4" lift. But since I'm slightly less than doubling the length of the arms, the forces are going to be greater.
Does anyone have experience with building custom control arms? If so, what size and thickness pipe should I use for my uppers and lowers?
I am using enduro joints and welding threaded tube inserts to steel DOM tube
All brackets are 1/4" thick
I'm building the jeep mainly for cruising offroad and doing small jumps, not much rock crawling is planned at all
Rear upper links will be triangulated
Running 33's, plan to get 35's later
I plan to use 1.5" OD tube with a .120" wall for my upper arms, and 2" OD tube with a .25" wall for my lowers; the thicker wall is for more resistance to denting.
My main concern is the diameter of my lower control arms. Is 2" strong enough for a longer arm? I'd rather go with 2.5", but I cant find threaded inserts that fit a 2" internal diameter.
Id appreciate any feedback, as even though I'm well educated in material science I have no experience applying it and can't find much information on this.
FYI this is my DD and I have cast outer knuckles, so i will not be doing any impressive jumps, mostly high speed cruising offroad and hitting bumps
