Sorry to start another no heat discussion... Jeep is 2004 4.0. I have been battling this since I got the jeep. Jeep has a 195-degree thermostat, new water pump, new rad, and heater core... did each one at a time over the summer. I have hot coolant that goes to and from the heater lines both about the same temp (flushed it anyways today to see, and nothing). The jeep stays just under halfway on the temp gauge when driving around. No clue why I don't even have decent heat the coolant level is good and have no leaks. ( last yr could partially defrost the window and this year not so much until it is at full operating temp but is still cool to the touch) Took the blend door actuator out and made sure it goes fully each way and that is all good. The only thing with that "system" is the knob on the far right (vent selector) needs to be turned with pliers as it breaks the knobs from being so tight could that be the possible issue? or can the heater core just be bad, had a shop do that in the summer. Any help is appreciated, thanks!
