I'm just here to talk about shocks and suspension tuning.
Just make sure you give a rap on the knuckles when you see silly questions regarding springs and joints. And short arm vs midarm vs other idealogies. The "tuning" will happen with shocks and getting everything else to play nicely with them. The only reason this build is getting a mid-arm is because I desire it, not because a short-arm would have been any less capable.
Just for some context, the black jeep got it's shocks tune adjusted again before it went to the new owner. I had the opportunity to experience the new tune very recently and it was just excellent. That jeep has now had 4 different shock tunes and each one has made it feel like an entirely different jeep. And I will point out that NOTHING else on the suspension was changed. Same springs, same links, same joints, same everything. Only thing changed is the shock tune. The latest iteration is now perfectly matched to how that vehicle sits in terms of weight and it was delightful to drive.
This orange jeep will get Fox shocks with DSCs, same as what @jjvw recently installed and talked about.
You and Josh are gonna make me spend another 1500 bucks on my shock project before I even install them.... you know that, right?
And it will be worth it![]()
As long as we all understand that we try to move forward with each tune which means that his tune will not be used, we'll try to improve it.This orange jeep will get Fox shocks with DSCs, same as what @jjvw recently installed and talked about.
You guys have me contemplating dropping $5000 on Fox Factory 2.5 DSC coilovers for my F150 for goodness sakes.
Properly tuned shocks is a real game changer on any vehicle.
Just buy a Raptor
Next, it was time to work on the front axle. The axle side LCA mount was cut out, and an Iron Rock offroad mount was welded on. You can see the tiny row of punched dots that are used to mark the location of the mount. It's a small detail but something borne out of practice and experience.
Next, the track bar bolt and stabilizer bolt reinforcement plate were added. You can see the bend in the bracket to get them exactly at the angle needed to get it to sit perfectly. Aso notice the hardware .. Blaine is a walking encyclopedia when it comes to understanding what hardware to use where and nothing is chosen without purpose.
Then, the factory cast control arm mount was removed and trimmed ...
... and trimmed exactly where it needed to be when the truss goes on.
please keep the build pro pics coming for those of us who prefer to flail through our builds ourselves but still recognize our long list of shortcomings![]()
What tool was used to cut the front control arm mount off? I like how tight the cuts are to the axle tube...
I told Blaine this will be a forever vehicle and as he is going through the build, he is doing all that is possible to seal things that need to be sealed, paint things that need painted and coat things that need coated all with the appropriate materials carefully chosen. You will see that in many places going forward from here.
And goes without saying - all photos are courtesy of Blaine. Like many of you, I have really enjoyed watching them on other threads but knowing these are on the orange jeep makes it extra special for me.
Front axle work continued .. Blaine welded capture washers to both the LCAs and then welded both mounts in place on the axle.
Then work started on the shock mounts.
Before -
and after Blaine cut them flush to the tube ..
and after he capped them off in preparation for the lower shock mount ..
Some of you may recall this photo from an earlier Blaine build thread showing shock mount. If you had wondered how all of that was built like me, now you know the steps. The work quality is really beautiful here
After those were done, Blaine welded the truss and stiffener. Weld thru primer was sprayed on the axle tube bare metal and inside any place that paint may not reach when the axle gets finally painted. Note that the stiffener is welded full length to seal out water to prevent rust on the inside.
Remember this from the previous page?
Now a mechanical connection is made with welding to unitize them together preventing relative movement. @mrblaine please correct me if I explained that wrong.
