Off-road tips?
What is the lowest danger area that I need to go measure and make sure I stay under it?
If the pumpkin is splashing thru the water you are almost guaranteed water will find its way into something with oil. And if you hear the exhaust bubbling under water. yeah water is coming in. But the easy solution is to change fluids, diffs, tranny, transfer case, after every water excursion. If there is water in it it will be obvious. If not, just put the oil back in.
Off roading is not cheap.
Reactions: Xposure
Thats what they say. Im putting 33s on it tomorrow ill test it with 33's and take a picture.
Did you get those 33’s on using the oem bottle jack? I wonder if it goes up higher than most cars oem bottle jacks? It’s easier to find a general used bottle jack than a Jeep Wrangler specific jack so it’s no different than any other jack I’ll just get one from some other kind of car. At the top where your Jeep rests on it, is it just flat where the frame just sits on it, or does it have a U that the frame can rest inside of?
I apologize I have not tried it yet. Its been hotter than hell.
Reactions: Xposure
Not to hijack but I cannot believe how hot it gets in PHX. It feels face melting hot. My wife and I love it here though and hopefully we will relocate here within the next few years
So I’ve read that TJ have some lower points that are easy for water to get into and damage. I know about the vent hole on the bell housing of the trans. I found out there are vent on the axles as well. What is the lowest danger point for water/mud? We will be doing trails and I know we will come across some mud holes as well as creek crossings.
What is the lowest danger area that I need to go measure and make sure I stay under it? I know the axles have vent lines on them that run up to the bottom of the body of the Jeep. Taking that into consideration what is the lowest point I need to be concerned with?
So far the lowest point to consider to make water damage to the TJ and let it permanent un operable is the headlight. At that height is the air intake entrance.
I will said that if you no want water inside the cab, side rails is the lowest point.
If you get stuck on a water hole that pass over your bumper height, be sure to keep the jeep idling over the 1200 rpm until is out. Exhaust may get water inside creating other issues.
No worry much about water going in to the Jeep or water crossings but worry about what is on the water that may damage your jeep.
Mud is tricky especially if no MT tires equipped.
Reactions: JMT and Xposure
Differentials, Transfercase and Transmission has breathers with and extended hose that reach over the air intake level. If they are in proper working order is noting to fear.
Edit; Fix typo and correct term
My tip for you is, Use your common sense. Study and know your Jeep, Play with it even around Home so you have the feeling of it. Don't be afraid of being a first timer but does not try to be an experimented fella either. Follow and Study ALL the suggestions above and execute them as better you think are going to work when you encounter any situation. Trails are full of non sensed jeepers but it also full of ones that are willing to help, suggest and share on any situation.
I do start wheeling by my own and sometimes with my girlfriend until start knowing other Jeepers. Be alone on the trails is a risk, mental toll and not fun so if you go with others you will feel more comfortable.
Good Luck!
you have a very special TJ, I have not seen that since the military CJs
Most of the time I do talk using my 04 LJ as reference, but pretty sure my 98 Sport has the same breathers.
Front diff end by the radiator left side
Tranny and transfercase end by firewall close to the hood seal
Rear diff end by the gas filler neck.
Do your TJ is not equipped with the same?
Reactions: Steven_Olson
If you go over your center hub you have the possibility of getting water in you front or rear axle. It really depends on what shape your seals are in. You could get it in the dif.
Im not saying that you will get it in there. But it is possible. I know a few people who change gear oil if the run deep. But i know others that don't. There is no consensus. For me it doesn't cost that much for piece of mind. I would do it all the time in my truck.
Reactions: Daryl and Xposure
Doesn’t the automatic trans inspection plate allow water in? If so, will that contaminate the fluid through the torque converter if it gets as high as the input shaft? Or is the torque converter sealed and water tight? It has to be sealed doesn’t it...if not it would leak fluid.
