Utah Official TJ Fest 2023 Thread
We were both kicking ourselves for not recording this Bronco rollover on the Gatekeeper to Behind the Rocks. I think we all recorded the prior broncs and mysteriously quit.
Reactions: RINC and Apparition
This is right after the Waterfall on Gold Bar Rim. To get up the waterfall I tried the direct line up the wall, but it was too steep. If you go to the right you can use the rocks there as a notch and walk right up. Then you can skip what’s in the video by staying driver, or do this which is more fun.
Is your rear locked? Looked like it wasn’t spinning at times.
Reactions: JMT
The vid doesn’t lie. I saw it right at the end when the driver rear seemed to not turn when the passenger did turn. Could’ve made that easier.
It’s not the only locker debacle we had that day @Rwd1960. Care to explain? 🤣
I’m curious as to what that means.
Here’s a pic looking at Hamburger from the opposite direction. You can see the cliff edge to the right side of pic.
Things were just warming up. If you do this whole trail unassisted you should get an official Jeff Badge. It’s no joke.
This is a SWB Bronco going up the Gatekeeper of Behind the Rocks. It gives some perspective for a TJ. I went up much easier. Video later. I took a strap midway up just for safety, but didn’t need it. This is the climb the other Bronco rolled on in an earlier video.
Reactions: Apparition
This is where we met Chris 2 ( there was also a Chris 1). He’s the only one who did this line.
He and Jeff became trail buds. See the resemblance? Ah, so sweet!!! 😉
