Definitely get or borrow a ln oil pressure test gauge from your local auto parts store... it's a 1/8" npt fitting. Unscrew the sensor... it's just above the oil filter and screw in the gauge. Best to prop it up or tape it someplace you can see it while driving.
IF you have no bad apparent oil leaks; it is either a bad oil pressure sending unit (as posted above) or possibly a piggy backed engine bearing.
Just because the part is new it still could be the problem. The junk “Chinese” parts that is being sold for replacement parts are not very dependable.
That's what I'm thinking right now I wish their was some actually good quality stuff out there!!!
I went through four before I finally found a Mopar.
Several years ago after purchasing my ‘01 TJ I started a spare parts cabinet for the important electronics parts and the parts you don’t want to settle for anything other than OEM.
The parts cabinet has most of the parts I need and occasionally I find additional parts to add to the spares.
If you're in there changing an oil pump you might as well do the rear main...that'll give you a good look at the condition of the bearings and it's a great time to document the size. That and it's really easy to roll main bearings in and replace the rod bearings. Plastigauge and a decent torque wrench and a little time. Also get a finger on the timing chain and decide if you need to go after it.
If you end up replacing the pump, and if you have higher mileage, go with the high volume Melling pump. It has a higher volume per rotation than stock (by about 15-20% if I recall correctly) which helps maintain pressure even with worn bearings.
It has the same relief/bypass valve PSI, so you won't overpressure anything. (At absolute worst, you'd be wasting a tiny bit of fuel to pump extra fluid through the bypass.)
Much more effective at protecting the engine than running higher viscosity oil, and also doesn't have nearly as much impact on fuel economy as higher viscosity oil.
