I didn't get to my 400P kit until the evening, so I'm late with the photos.
A 25' Flexzilla hose will fit in the Viair bag, but tightly. The reason so many are now using Flexzilla or similar air hoses is that they are easier to handle than a coiled hose, don't take up much more room if anymore at all, and they are repairable in the field.
The bag itself has a 12x7x9h main compartment and a 12x4x4 outside zippered pouch for the coiled hose. There are two pockets on the sides for air gauges and other stuff, but they are relatively useless. If the bag were 12x9x9 there would be enough room inside for the compressor, hose and and inside pocket for air gauges, deflators, etc. and there would be no need for the 12x4x4 outside pocket - perhaps a zipper or zipper and flap to an inside pocket instead.
The big issue is a hot compressor after use - in order to put a hose of any type or brand in the bag without damaging the hose or the bag there is wait time until the compressor head cools down enough. I resolved that with a 12"x12" welding blanket I found on Amazon that I drape over the hot compressor to insulate it from the bag and other contents until the compressor cools - I just put the hot compressor in the bag, lay the welding blanket over the hot compressor head, put the Flexzilla hose on top of the welding blanket, stow my filled and zippered compressor bag with hot compressor inside, and get on with what I am doing. [At least that's what I did before I acquired a used Viair 400H compressor that is now hard mounted under the hood of my jeep. My 400P kit is now a spare.]
The other issue the the flap and carry handle. All the Viair bags are the same design, which relies on two plastic fasteners for strength. I would think a handle made from webbing that extends all the way around the bag cradles the bag from underneath would be considerably stronger and better for something the weight of a compressor and accessories.
View attachment 209075View attachment 209076View attachment 209077View attachment 209078View attachment 209080
Links to the 400P kit, Flexzilla hose, open flow air chuck, and the 12x12 welding blanket:
https://www.amazon.com/dp/B000X9AXR8/?tag=wranglerorg-20
https://www.amazon.com/dp/B000R8BOWS/?tag=wranglerorg-20
https://www.amazon.com/gp/product/B017S44ARO/?tag=wranglerorg-20
https://www.amazon.com/dp/B07PYZXPHK/?tag=wranglerorg-20
