Glad there is no more pain!I lost what little of what I had for walking side hill and it had arthritis from the original 32 year old injury. the plus’s are no pain and I can’t roll my ankle. Yes it was my left foot.
Hey you finally won ROTM, congratulations Brah.
What about a vibration induced from the engine? Balancer? Something out of wack (bearing) in the transmission?Something has definitely given up the ghost, and after today's test, it's either the rear drive shaft or something in the rear end. I double checked the rear pinion angles and that is tits. Put the rear end up on jack stands and brought it up to speed. Vibes start to kick in at 45mph and get so bad it vibrates the rear view mirror and hard top glass. Something must have finally broke after my MNF trip with Tom, cause that is when the vibes got noticeably worse. I think I can rule out a bent axle or bad wheel bearing because when I ran it without the rear DS, no vibes.
No vibes when running without rear DS.What about a vibration induced from the engine? Balancer? Something out of wack (bearing) in the transmission?
Then I would like maybe transfer case rear output bearing? Or in the diff.No vibes when running without rear DS.
Easier way is crack the cover and take a look!Could something have gone haywire with the factory Traclok? Clutches blown up? Springs grew legs?
How does the Tracloc behave in coast? Could it be that something happens under load that doesn't when it is on the coast side of the gears, say, when the rear DS is removed?
And this is with or without the rear DS.Vibes stay the same under load and at coast. I've put it in neutral and coasted down the freeway in a down hill at 70mph, and with the engine idling while coasting the vibes are the same.
Edit: I see what you're saying. So it has nothing to do with load/coast. If it doesn't happen with the rear DS removed I would think it has to be isolated to T case output, driveshaft, or maybe pinion yoke?
My transfer case switch went bad on that same run!Something has definitely given up the ghost, and after today's test, it's either the rear drive shaft or something in the rear end. I double checked the rear pinion angles and that is tits. Put the rear end up on jack stands and brought it up to speed. Vibes start to kick in at 45mph and get so bad it vibrates the rear view mirror and hard top glass. Something must have finally broke after my MNF trip with Tom, cause that is when the vibes got noticeably worse. I think I can rule out a bent axle or bad wheel bearing because when I ran it without the rear DS, no vibes.
You and I have cursed TJs.
FWIW - I called balance masters and had a long chat with them. They don't make the ring in the size I need for the rubicon rear driveline (the front driveline is 2" dia, and the rear is 1.90" dia). I bought the 2" they sell and it is sitting in my garage. If that size will work for you, PM me your address and I will ship it to you to try out. The ring is simply a thin rubber donut with what sounds like small ballbearings inside.
I am waiting to take my rig to Dave so that I can get some suspension work done and take another stab at the vibracrap. Dave has promised to check the gears very thoroughly. I am going to get a new rear driveline ... I think that's where my problem is. This should be happening soon ...
Yeah, my rear DS is 1.90" also, but maybe I could build it up with vinyl tape or something to get it to clamp tight?
Not sure how good of an idea that would be ..
BTW - have you tried the hose clamp balancing trick at all yet? It was there in that giant PM conversation we had a while ago. If you can't find the link, let me know and I will find that video again. It's actually prescribed in the FSM as a hail mary for really troublesome drivelines. This is one way to do on-vehicle balancing. What the specialty driveline shop did for me is a more advanced version of this (they had some software and hardware tools to do this in a better controlled fashion). It made a difference for me.
