"Pacing myself" build
Do you have a reason to believe it is the axle shafts or are you buying them just to be safe?
I don’t remember, have you replaced the rear bearings? I’d expect noise more than vibes unless the press was bad, but you’re into a hell hole of unknown unfortunately :/
I do not, other than thinking it has to be related to the rear end in some fashion. I guess I just like throwing money at this turd! I'm focused on rolling mass, and the axle shafts are spinning.
I replaced the right rear axle bearing/seal when I re-geared cause the seal was leaking. Think I will pull the shafts and run it tomorrow. If I pull the shafts I might as well install the one's I got from Alex.
Reactions: lowranger
@Chris can we get a 🤞reaction? That seems appropriate here
I guess you'll be able to "send it" up any obstacle lol.
Since I have my jeep apart, in preperation for the new skid next week, I pulled the rear shaft. I have no more than a piece of paper thickness worth of play in the rear input shaft of the t-case.
I measured today, and have less than 0.020" of out play on the yoke, so I don't think the t-case is the issue. I could be wrong. I figure if I'm going to pull the rear shafts, I might as well change them to see what happens.
Rabbit hole again ..
Did you see that video with the hose clamps?
What's best way to upload video? I tried Vimeo, but the file is too large.
I first put the jeep on jack stands and got my butt dyno baseline vibes.
I then pulled the wheels and ran it again. Same results.
I pulled the rotors, axle shafts and ran it again. Same results.
Time to pull the diff cover.
Cleaned up the carrier and inspected stuff.
Ran a tooth pattern.
Spun it 180* and ran a pattern.
Got some weird results on the second pattern check at the 180* mark. At this point I had the axle shafts out and was doing my best to put some pressure on the ring gear with my hand as I turned the rear ds, so that may or may not have something to do, or, my ring gear is warped.
Next, I checked back lash.
Yep, you saw it. 0.14 back lash. I flip the tool around to the top and measured again to be sure and got .015. Specified range is supposed to be 0.06 - 0.10.
So basically, the gear setup is fubared. Not sure how that causes the vibes, so I'll have to leave that to someone that knows way more than me about gears.
Reactions: DrDmoney and Alex01
Put it all back together, slapped some fresh gear oil in, put my tail between my legs and drove home in disappointment.
  • Sad
Reactions: DrDmoney
