I had to remove the tire carrier from the Rock Hard bumper to get the holes drilled for the corner armor. After looking at it all stripped down, I decided to just pull the entire bumper and go with a high clearance option instead. I've been toying with that idea anyways, so since the work of removing it was half done, I just went all the way
I originally went with this bumper for a few reasons - this TJ was originally for my daughter so I wanted something reliable without rattles or issues. It also was cheap (I bought it used!) and is one of the few with a rated tow hitch. Now that it's become my toy and the build plan has modified some, it's time to make this as "trail skinny" as I can get it.
The +200 lbs of weight saved off the very back of the Jeep is already noticeable! This of course leaves me with "what to do?" for a spare tire mount (it's currently just thrown in the back of the tub), but I want to think and ponder on that some before making a decision...
Speaking of wheels and tires, I've been eyeing up a set of beadlocks on Marketplace for sometime now. I made an offer, figuring that the holidays were a good time for most people to get an influx of cash in their pockets, and the seller accepted. They're 17x9" Battleborn Bootleggers and came with a brand new set of Discoverer SST Pros. Unfortunately, these SST's are 315/70 E-load rated - so not appropriate for the Jeep. That said, they will work nicely on my RamCharger so that's where they will get once I get some time to pull the rings and press these off...
I did a test fit of the wheels and it was apparent that the lugs were way too short - only about 3-4 threads of engagement. I did some digging around and it looks like many folk just run the later-year XJ/TJ front studs in the rear axles. The knurl diameter is a bit bigger (0.627" vs 0.618") but they pressed in without any issue. I should have about 11-12 threads of engagement now. SAE says you need a minimum thread engagement equal to the diameter of the stud, so on a 1/2" stud I need 1/2" threads engaged. At 20 tpi, I should be slightly over that. I may still order a set of "ET" lug nuts but this should get be around for now.
I know it goes against wisdom and convention - and may get some slack for this (even from myself!) - but I ordered a new set of 37" x 12.5" MTR's. I don't intend to run these axles for too long - but with the Hemi swap, paint job, and move up north coming up in the next 5 months, I don't have time to shorten and build the D60KP/14B. My ultimate goal is 37"s on 65" WMS wide axles with both a TJ6 stretch as well as conventional 4-5" rear stretch (conventional stretch first, followed by TJ6 as I can source the parts I need).
I don't want to buy tires twice and having them on hand will make it handy for other things (like building a mount for the spare in the tub). I got a smoking deal on them from my local Discount Tire, plus with the holiday sales going on, it was just good timing, albeit early
