Hello all!
I've had my TJ for about a year now, it is a 2004 wrangler X and its been quite the adventure. For the entire year i've had speed sensitive vibrations that I have tried to get rid of.
The past year I have removed the front driveshaft due to damage on the body and replaced the rear driveshaft with a Tom Woods shaft. I had a old set of 31" MT's that I had balanced 3 times with multiple shops, this only caused the vibration to change in speed and intensity. I felt defeated and purchased brand new K02's, the vibration was much less but still persisted in the 45-55 mph range. When I let off the gas pedal the front end vibrates a little more violently and the steering wheel will shake a little bit but the steering wheel shake stops below 50mph. After I had put in the Tom Woods driveshaft the steering wheel shake mostly stopped but now I feel a "choppy" vibration in the gas pedal, seat, front dash when going between 40-55mph. Below or faster the jeep is mostly smooth.. not completely but not shaking. I will add at the tire shop that put on my new tires said my wheel were really hard to balance, they have massive amounts of weights on them (almost like a whole sheet on each tire)
I have no lift on my jeep just 31" tires on 15" wheels, everything else is stock, and I still have no front driveshaft due to cost.
I am kind of thinking this could be a slightly bent wheel or axel issue. What do you all think?
