Took the day off to work on cleaning up the garage. Did a dump-run after that. Decided to change the oil in the S10 Blazer. 4.3 V6 in it. Filter is easy to get to. I'll wash the rig after I'm done. Riiiight...
Two and a half hours later, the filter is a shredded mess of tangled metal. Using the proper tools was futile. It's on so tight that a cup-style tool just started to collapse the filter. An oil filter wrench self-destructed trying to remove it. Eventually, I had to resort to the old "screwdriver through the filter" trick, but all that did was rip the metal. I have exposed enough of the base of the filter that I can see the holes in it. I tried a punch and a chisel (and hammer, obviously) to smack it loose, but to no avail. I may have to resort to welding a socket to the base and seeing if that works. All I know is that the dealership's "mechanic" (original owner only took it to the dealer for all the maintenance) should have his knuckles smacked for putting it on so f'n tight. I'm actually wondering if he cross-threaded it, and that's the issue. And yes, before anyone asks, I've been turning it the correct direction for removal!
