- Price
- 12500
- Location
- Leonardtown, MD
My brother is selling his 2003 Moss Green TJ X. It’s a 4.0L 42rle auto trans, 128,000 miles, dana 30/35 with stock 3.73 gears and no 231 transfer case. We swapped a new frame onto this Jeep and refreshed a lot of parts in the process. The cooling system has been refreshed with a new radiator, water pump, thermostat, fan clutch and hoses. The valve cover gasket was replaced with one from felpro, the transmission fluid and filter was changed and a lube locker gasket added. It has a 1.25 aluminum body lift with brown dog rubber motor mounts, 2.5-inch lift with rancho RS5000X shocks, Metalcloak adjustable front track bar, JKS disconnects, and extended length upper and lower control arms. The front end was rebuilt with new spicer ball joints, timken bearings, axle seals, a lock rite locker, alloy USA 5/16 stamped steel diff cover and Currie weld on lower control arm skids. The driveshafts were also rebuilt using spicer joints and center ball kit. The Jeep has 33-inch Patagonia MT tires on 15x8 Steel Wheels, Mopar Enhanced Rock Rails, Jeeperman rear swing out bumper, front winch plate with 9500lb winch, UCF engine skid, steel high clearance gas tank skid, and a newer tan top from Bestop. All the parts and upgrades were added in the last year and it’s been on the road for the last 4 months. It runs great down the road with no vibrations, still have factory slip yolk and washers in the t case skid. He never keeps things long and is looking to get into another project so I told him I’d post it up and see if anyone is interested in a really clean, rust free, turn key daily driver/weekend wheeler. Jeep has a clear and clean title. Let me know if your interested and I’ll get you connected. Thanks!
thread with pictures a progress here
https://wranglertjforum.com/threads/03-x-frame-swap-and-freshen-up.45798/
He’s looking to get $11,500 or best offer.
