Thanks again. I will look into doing that or getting it done.Thanks, I could pretty much say the same thing as you did there. Only replacing the cats proved to be the cure for the repeated errant bad O2 sensor codes. I haven't had an O2 sensor code in the several years since both precats were replaced.
