So I'm working on cycling my suspension after installing the Dana 44 I bought. I installed the track bar with the weight of the vehicle on the ground and centered it. I then removed the coil springs to cycle it. On the driver side I can't get the spring pad all the way up to the upper bump. Mainly due to the sway bar link mount hitting the frame, but it still wouldn't meet on center because the pad is shifting towards the right and off center. Passenger side almost makes it but also falls short. Anything I'm missing to make this work or am I looking at removing the link mounts? Thanks
