Well ask away and if you need to see video of something, I might have it.
I'll be pulling my transmission soon. I talked with a shop and their rate is reasonable, but the more I think about it, the more I'd like to add some heat/sound deadening stuff in that area and secure my wiring better, protect the wiring and finish my straight pipe exhaust. I might touch up part of the frame with the POR 15 while the skid plate is out too. It's pretty miserably hot now, so I'm not too keen driving the Jeep a lot, though none of my vehicles have AC so it doesn't matter, but the lack of insulation is noticeable in the TJ vs my truck.
I'm trying to find out info on the 4.3 first gear for the AX-15. I've emailed Marlin Crawlers and if possible I may just have them build me a custom transmission. I guess it depends on the price really. But I'd like to have a new transmission to go with new tank, engine, and in the next year or several new Tcase and axles/diffs. I think with the 3.55s, and 4.3, I'll get about 30% reduction in speed in first gear, which should be noticeable and only slightly annoying on the street, unless I am pulling something.
When I save up for the Atlas (2) 5:1, then I'll be rocking a crawl ratio of 76:1, which isn't bad for ditches, mud, steep terrain, etc. My truck is around 60:1 and it's night and day vs my low 30s Jeep setup. I might add that as far as mud goes, unless the truck bottoms out, it gets stuck a bit less. When it gets stuck it's horrible to get free.
