Been driving the Jeep for the past couple days, but just short trips since most of the wiring isn't done. Fan is wired in though it's not working yet. Been using the Murphy gauge to keep an eye on my coolant temp. Waiting on this electric instrument panel
https://www.intellitronix.com/product-page/jeep-97-06-tj-led-digital-gauge-panel in hopes of the wiring process to go a lot smoother. Also thinking of writing Axis a nasty email. I was reading over your other forum posts and got a lil pissed off when you mentioned Axis returns your calls. They won't do that with me or respond to my emails. I'll be sure to tell them it's sad that I'm getting most my info from you and not from them. Again thank you for being a reliable source and for answering all my questions thus far.
Well I've got to call them too. I was out camping on our farm and it's a bit remote. I got packed up and was going to head to my granddad's cuz he rolled his Jeep and was going to figure out all the damage.
I tried to start like usual and heard the starter free spinning something light with a bit of a sheet metal sound. I didn't have tools to remove the starter, but I was pretty sure something with the adapter had come loose. I didn't want to roll start because I was afraid whatever was loose might cause some real damage. I might add that it was fairly hot. Also your normal tow truck can't get to where I'm at and there's no address which complicates things.
I called my wife to come to the nearest/easiest walk out point and grabbed some gear I didn't want to leave.
I met her and we went home. I picked off a bunch of ticks, had her cut my hair, ate some food, grabbed my truck and went to go get my trailer and unload it and got my dad to help.
Right before we got to the farm with the trailer, it had poured rain and if I hadn't just picked up dedicated mud terrains for the truck, I'm not sure we would have made it in.
I pulled the starter and the adapter was secure, but the welds on the ring had all broken. I had been thinking I must have messed something up and the bolts backed off, but there's only 1 little ring in there spinning.
We loaded the Jeep onto the trailer with some come alongs and hand winch, which worries me since the trailer is older than I am I think, but it didn't break. It had been dark for awhile at that point, but ratchet strapped down the Jeep was fairly secure.
The muddy steep hills I barely got up were making me nervous because I wasn't sure how controlled I'd be going down such steep grades. Luckily I wasn't thinking about slipping down the hills.
The steepest part I got pushed and slipped down, but only for a bit and going straight. I could hear the wet ground squishing under the truck as we went through one of the fields and tried to weave in and out of ditches you can't see with all the brush.
The last hill has some holes, ditches and uneven terrain and at one point the trailer started going sideways and the truck wasn't going very straight, so I just pushed the clutch in and used momentum to straighten everything out and to go through the last ditches that tend to bottom the trailer out.
Once on the road it wasn't bad, but I didn't finish up until 1:30 am and I haven't unloaded the Jeep either. I was pretty tired and a couple glasses of bourbon while picking off deer ticks and checking out a gnarly spider bite on my back, put me in pretty good spirits to start over sometime today to get the Jeep unloaded.
