Radio replacement
Dcook65
Sharpsburg, GA
My tj has an aftermarket radio. I want to replace with a Bluetooth radio. It is single DIN. Will I need a new mount kit or will the old one work? From what I know single DIN radios are all the same size.
Single din is single din. Get another and it should fit just fine. You may need to change the "cage" to the one that comes with the new radio. Heck, the wiring is probably even the same color code.
Not sure what you mean by “cage”
