I'm in the same process right now... after being in trouble twice the same week (one because of the trans shifter bushing popped out, another because battery wiring was a mess and dirty) been thinking on doing a tune-up as well although I'm not really sure what that exactly means.
I got my '06 TJ a couple of years ago with around 105k miles on it, its going to 120k. I've done a lot of work on it from every part I thought was critical at that point as it was in a pretty bad shape when I got it and the former owner is known to be careless. Whole cooling, AC, hoses, suspension, brakes, etc. changed.
So anyway, I've done the usual oil/gaskets/filters stuff as needed but I was thinking on changing the main wiring as it is pretty worn and the spark plugs once I'm in that process which then took me to the rabbit hole of what else should I change for the
peace of mind the rail as
JKLNHYD says.
So my idea is to do an electrical/ignition tune up, again, don't want to have trouble down the road plus this is my daily driver:
- Custom battery cables from this guy who does specifically that
- The Autolite XPXP985 spark plugs as they seem to be the recommended option in so many threads if you have the coil rail
- Ignition coil rail, there's a cheap Duralast one on autozone for around $75, then there's the mopar for $200. I usually don't cheap out on critical parts so if there really is a difference I rather have the OEM but if its just the name then it's a waste of money of course
- Upstream oxygen sensor, there's this one on Amazon, a Bosch, $35, but I've heard they are not the best sensors for jeeps
- Downstream oxygen sensor, again, a Bosch, in Amazon, $45
- Injectors?, There's these remanufactured which are 4-port from ksuspensionfab which seems to be popular in these forums, around $115 bucks
Of course #1 and #2 would be the basics, the other's are just things I'm kinda inclined to do as well while I'm at it.
I just saw a guy today doing a tune-up on
his TJ on youtube that went as far as changing all sensors in the throttle body... not sure if that is even required either. I have no codes thankfully but I do feel that a 15 year old car definitely can broke down on worn parts or those which are supposed to do anytime.
This is my second jeep, I used to own an XJ but really I've been
learning with the TJ recently so bear with me if these are just too many questions/points
I rather start doing myself these things now than to take it to a shop unless it's something really complex.
