I've been doing a few each day after work at a pretty lazy pace which has been kind of fun actually.
Here's a super dry joint:
Need more hosing down with fluid film2 years now. About 20k miles.
Wow...Those are worse than the ones I got that came out of Chicago and were many years older...I've been doing a few each day after work at a pretty lazy pace which has been kind of fun actually.
This accelerated wear is all from the road salt in the winter?
Am I reading that right, you apply both fluid film and CRC?I am a big fan of Fluid Film, I do the underside of my jeep and truck twice a year, but I also use CRC corrosion protection, marine grade. It has been tested by individuals (not CRC) in a salt bath and holds up better than most, what are your thoughts on spraying the JJ after it is all assembled with the CRC?
jjvw had the same contact point , no? what abut increasing that bend like he did?With the front axle drooped out I discovered that the Currie steering hits the antiswaybar rod end. There's a few marks on on the tie rod end showing that this apparently has happened file driving. I've been wanting to dial in more caster anyway, so I rolled the axle back to add more caster which also gave more room between them. They still touch and I don't want to pull the axle back further, so I think I'll be using Black Magic Brake's antisway bar relocation brackets.
For some reason the front JohnnyJoints stunk when I opened them. It looked like there was several types of grease in them.
Rebuilding the front end solved the noise that started over the last few months.
I need to bring the tires in to Discount Tire for balancing sometime before winter.
LPS works well too. we coat steel going overseas on 2month long ocean voyages. it's a heavy waxxy coating.I am a big fan of Fluid Film, I do the underside of my jeep and truck twice a year, but I also use CRC corrosion protection, marine grade. It has been tested by individuals (not CRC) in a salt bath and holds up better than most, what are your thoughts on spraying the JJ after it is all assembled with the CRC?
I use the CRC in places where the Fluid Film may not provide enough protection (it tends to wash off more readily than the CRC). So I spray the CRC up into the torque boxes, inside the frame rails, etc. The FF I spray (I bought the spray gun and buy FF by the gallon, way cheaper) under the entire vehicle, most especially in the wheel wells, all around the brake lines, and just overall coat the underside of the body..... I wish I would have done it from the day I bought the LJ brand new....Am I reading that right, you apply both fluid film and CRC?
.i know i asked about these relocation brackets when i saw jjvw used them. i had to pass as it was stated it may not have enough offset for my wider axles. but the other issue would have been the location of my TB axle mount on the C.
can anyone verify the distance off the tube forward to the inside of the bend. unless i'm mistaken again he has a similar mount on the C. if the bend is beyond his TB joint he can get around it, but could require some cut n fit to avoid it on the C.
this is what i'm talkin about. unless things have changed, this it looks a little crowded. maybe i'm mistaken ...sorry if thats the case, and disregard.On a stock axle, the BMB brackets put the sway bar links at the same width as stock, just a bit higher and without as much stuff occupying the space below. If the inner C's sit wider than stock, then the lower ends of the links will also be wider.
Are you confusing two different vehicles?this is what i'm talkin about. unless things have changed, this it looks a little crowded. maybe i'm mistaken ...sorry if thats the case, and disregard.
https://wranglertjforum.com/threads...story.9956/page-17#lg=attachment69122&slide=0
