I don't care for my TeraFlex front sway bar set up as it is too stiff when engaged and I don't need a quick disconnect. It was making some noise and I ended up taking the sway bar links off and tying them up out of the way. Jeep rides much better completely disconnected. It does have more body roll now of course. I am thinking the stock set up would be better for ride quality. I figured I should run this by the group. I have the OME 2" lift. Can I just get all the stock parts, or is it like the front track bar that needed to be replaced with an adjustable one if you want to do things right? Thanks for any advice.
