Replacing the coil springs
There is no way the rear OME is 160. The Moog 3227 I ran is 200 and so is the BDS. The factory spring is 180 if I recall correctly.
ETA: I suppose the OME could be 160. From what I could find the factory is 140 or 160. The BDS as well as the Moog are very nice riding, almost too soft with no load.
You have RS5000x right?
It could also make it up in extra length (you'd have to put the bds and OME springs side by side to say) but a lower spring rate with extra wraps means more preload so the same ride height.
There must have been a time
when we could have said no.
