Rather than just say "no benefits," let me share some of my non-guru thoughts.
The rail sits in a hot location on the engine. Electric components and heat are not a good mix. If this design was so genius, why don't they still use it? Yes, I understand engine design, but you likely get my point. Sometimes bad designs go away and don't come back. With the relocation bracket, it moves it away from the block. This may provide longer life and avoid catastrophic failures on the trail.
Have you ever had to isolate one cylinder with the rail design? You really can't. Not without taking it off first. That alone is a benefit. Period.
One other thing, in my case, that may be the reason (aside from the rail becoming coincidentally damaged right after adding a turbo) for my dramatic benefits (by the way remain outstanding today) is that a hotter spark may compensate for "turbo spark blow-out." If someone didn't read that this is a Banks turbo with intercooler, they might not consider that. However, when you add compressed/ cold air to a system, you likely will need to dial in a few other systems. Next is going to be big exhaust air. Get that little wheel spinning quicker.
This is a hobby for me. I could have gone crate 1000hp on a CJ (well, at least the VIN) over 60s. But, that's not MY project. My project is trying to bring the most out, while keeping the most I can in.
Although, could you imagine a turbo diesel 4cyc option for the TJ! Wanted to do that bad. But, I live in California and just thinking about doing that resulted in a fine from the thought police.
I really hope to share my completed Rubi in December (February more likely). Perhaps enough of you will see what I was going for to get me that sweet, sweet Ride O' the Month title.
